Reset
LAB
Reset
LAB
Reset Lab · Miami, FL
Laser Hair Removal
Permanent Reduction
Stop shaving. Stop waxing. Laser hair removal delivers long-lasting, permanent reduction of unwanted hair on the face and body — for all skin tones — with precision, comfort and results that compound with every session.
Laser Hair RemovalPermanent ReductionFull BodyFace & NeckBikini & BrazilianLegsUnderarmsBack & ChestAll Skin TonesNo DowntimeMiami FLLaser Hair RemovalPermanent ReductionFull BodyFace & NeckBikini & BrazilianLegsUnderarmsBack & ChestAll Skin TonesNo DowntimeMiami FL
THE PROCESS
How Tox Works
01
CONSULTATION
Your provider assesses your skin tone, hair colour, hair density and treatment goals. A patch test is performed to confirm your skin’s response and calibrate the laser settings precisely for your individual profile.
02
SKIN PREPARATION
The treatment area is cleansed and shaved immediately before your session. A cooling gel or integrated cooling system is applied to protect the skin surface and maximise your comfort throughout.
03
LASER TREATMENT
Pulses of concentrated light energy are delivered to the treatment area. The laser wavelength is absorbed by the melanin in the hair shaft and travels down to the follicle, generating heat that disables its ability to produce new hair without affecting the surrounding skin.
04
GRADUAL PERMANENT REDUCTION
Each session targets hairs in their active growth phase. Since only 15–20% of hairs are in this phase at any time, multiple sessions spaced 4–8 weeks apart are needed to achieve comprehensive coverage across all follicles.
Treatment Areas
Head to Toe —
We Cover It All
Face & Neck
Upper lip, chin, cheeks, jawline, sideburns and full neck — ideal for clients managing unwanted facial hair or post-wax irritation.
Underarms
One of the most popular treatment areas. Delivers smooth, dry underarms permanently — and eliminates the skin darkening that can result from chronic shaving.
Bikini & Brazilian
Full bikini, extended bikini and Brazilian options available. Precise treatment in a sensitive area with technology calibrated for comfort and all skin tones.
Legs
Full leg, lower leg and thigh options. One of the largest surface areas and one of the most transformative — freeing clients from daily shaving or monthly waxing.
Back & Shoulders
Targeted treatment for the full back, upper back, shoulders and upper arms — effective for both men and women managing dense or coarse body hair.
Chest & Abdomen
Precise hair removal across the chest, stomach and lower abdomen. Ideal for clients seeking a cleaner, maintained appearance without the irritation of regular shaving.
Our Financing Options
Preparation
Before
Your Session
  • Shave the day before — no waxing or threading for 4 weeks prior
  • Avoid sun, tanning beds and self-tanner for at least 4 weeks before
  • Arrive with clean skin — no deodorant, lotion or product in the area
  • Pause retinoids and photosensitising medications for 5–7 days before
  • Disclose any recent sun exposure, active infections or prescriptions
Aftercare
After Your
Session
  • Apply gentle moisturiser or aloe vera for the first 24–48 hours
  • Avoid sun and apply SPF 30+ to treated areas exposed to daylight
  • Skip the gym, hot showers and saunas for the first 24–48 hours
  • Treated hairs will shed over 1–3 weeks — this means it's working
  • Shave only between sessions — never wax, thread or pluck
What to Expect
Your Results, By the Numbers
6–8
sessions
Recommended for Optimal Results
90%
reduction
Average Permanent Hair Reduction
4–8
weeks
Between Sessions per Body Area
downtime
Return to Daily Life Same Day
FAQ
Common
Questions
Everything you need to know about laser hair removal at Reset Lab Miami. Still have questions? Call us or book a free consultation.
Laser hair removal delivers long-term, significant reduction in hair growth — typically 80–90% or greater after a full series of sessions. A small number of hairs may return finer and lighter over time, and occasional maintenance sessions can address these. It is classed as permanent reduction rather than permanent removal.
Most clients describe the sensation as a warm snap or flick against the skin. Modern laser systems include integrated cooling technology that significantly reduces discomfort. Sensation varies by treatment area — bony areas and sensitive zones tend to be more noticeable, while larger flat areas are typically well-tolerated.
Most clients require 6–8 sessions to achieve comprehensive coverage across all hair follicles in an area. This is because the laser only effectively treats follicles in their active growth phase, which represents 15–20% of follicles at any given time. Sessions are spaced 4–8 weeks apart depending on the body area.
Yes. At Reset Lab, we use laser technology suitable for all Fitzpatrick skin types including darker skin tones. The specific wavelength and settings are calibrated during your consultation to treat your hair safely and effectively regardless of your skin tone.
Laser hair removal uses a single, concentrated wavelength of light that can be precisely targeted to the hair follicle at the correct depth. IPL (Intense Pulsed Light) uses a broad spectrum of light, making it less precise and generally less effective — particularly on darker skin tones. At Reset Lab we use medical-grade laser systems, not IPL.
Treating tanned skin significantly increases the risk of burns, blistering and pigmentation changes. We require clients to avoid all sun exposure, tanning beds and self-tanner for a minimum of 4 weeks before each session. If you arrive with a visible tan, we will reschedule your appointment to protect your skin.
Absolutely. Laser hair removal is equally effective and popular among men. Common treatment areas include the back, chest, shoulders, neck, and beard shaping. Settings are adjusted to account for the typically coarser and denser hair found in these areas.
Shaving is the only acceptable method of hair removal between laser sessions. Waxing, threading, epilating and depilatory creams remove the hair shaft from the follicle, which is required for the laser to be effective. You will notice treated hairs shedding over the 2–3 weeks following each session — this is expected and confirms the treatment is working.
Get Started
Ready to Be
Permanently Smooth?
Book your laser hair removal consultation at Reset Lab Miami. Our licensed providers will assess your skin and hair profile, walk you through your treatment plan, and get you started on the path to permanent freedom from shaving and waxing.
